Inventor Forum
deleting parametres
2 REPLIES 2
kmeldfreyssinet
255 Views, 2 Replies
deleting parametres
Can I somehow delete model parameters that are not used?
I have a part with some model parameters and a lot of user parameters.
Now I would like to prepare a tamplet file based on this part. So I removed all modelling oprations, and I also would like to remove model parametres.
Is that possible?
Cris.
2 REPLIES 2
Hi..
Try the following app:
http://apps.exchange.autodesk.com/INVNTOR/pt/Detail/Index?id=appstore.exchange.autodesk.com%3Apurged...
The program will search for all unused parameter and list them in the dialog box allowing the user to delete selected parameters.
Asidek Consultant Specialist
www.asidek.es
Dropjeslover
in reply to: MariaManuela
If it is not used, right-click the yellow circle on the same line as the parameter name (on the right, next to the parameter result colom). It'll give you the option "delete"
