"I havent tested to see if this still works in R6"
It does..
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Drew Fulford" wrote in message
news:57EFF194DFC2C562E9011DB2C6E286E1@in.WebX.maYIadrTaRb...
> There is a workaround way defined at my site.
> See Inventor tips & tricks 2011 http://www.mymcad.com/
> - drew
> Drew Fulford B.A.Sc. Systems Engineer
> Solid Caddgroup Inc. Burlington, Ontario
> Tel: (905)331-9670, Fax: (905)331-7280
> Corporate: http://www.solidcadcam.com/
> Member of the Autodesk Discussion Forum Moderator Program
> Visit my MCAD website @ http://www.mymcad.com/
> "JohnHerbert" wrote in message
> news:f12a34a.-1@WebX.maYIadrTaRb...
> > hi all - i wanted to know if there is any way to limit the range of
motion
> of a part. i need to limit the range of motion of a piston to be four
inches
> of travel. currently the picton is constrained to be concentric with the
> housing it is in, but once the assembly is put together the piston can be
> dragged through the housing . . . .
> > Thanks so much -
