Inventor General
Active Member
Message 1 of 2 (266 Views)
default k factor value
266 Views, 1 Replies
06-21-2004 05:36 PM
Can anyone help me set the default k factor value to 0.33.
I do use a sheet metal template. I use a standard part template and then change it to sheet metal by selecting applications and then sheet metal; but then I also have to change the default K factor from 0.44 to 0.33. I want to remove this last step.
John
*Bob Van der Donck \(Autodesk\)
Message 2 of 2 (266 Views)
Re: default k factor value
06-21-2004 08:54 PM in reply to: Johnb
Should be as easy as going to the "Sheet Metal Styles" dialog and hitting the "Modify list" button. Simply overwrite the 0.44 value with 0.33 or add a new value and set that Kfactor value active in the dropdown. Save your results to your sheet metal template. Bob
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
