Inventor Forum
default k factor value
1 REPLY 1
722 Views, 1 Reply
Can anyone help me set the default k factor value to 0.33.
I do use a sheet metal template. I use a standard part template and then change it to sheet metal by selecting applications and then sheet metal; but then I also have to change the default K factor from 0.44 to 0.33. I want to remove this last step.
John
1 REPLY 1
Should be as easy as going to the "Sheet Metal Styles" dialog and hitting the "Modify list" button. Simply overwrite the 0.44 value with 0.33 or add a new value and set that Kfactor value active in the dropdown. Save your results to your sheet metal template. Bob
