Inventor Forum
decal feature
10 REPLIES 10
Message 1 of 11
595 Views, 10 Replies
decal feature
this new feature looks cool but i can't get it too let me browse for my .bmp
... i hit image but no browse. What have i missed here?
Brian Land
Mechanical Design
Lorik Tool Inc.
10 REPLIES 10
Message 2 of 11
You have to make a sketch and insert the bmp there. Exit the sketch then
issue the decal command and choose the bmp from the sketch.
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Brian Land" wrote in message
news:8EB14CCE2D6EFB3868A76ECB21FB984E@in.WebX.maYIadrTaRb...
.bmp
> Brian Land
> Mechanical Design
> Lorik Tool Inc.
Message 3 of 11
i was hoping i missed the browse somewhere...(-:
thanks again Sean
"Sean Dotson" wrote in message
news:61DA4AFBCF93827127175619FB5A78F2@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> .bmp
> > Brian Land
> > Mechanical Design
> > Lorik Tool Inc.
Message 4 of 11
1) New sketch (on face of part)
2) Click on "Insert Image"
3) Browser window opens
4) Find bmp
5) Use dimensions to size and constrain bmp on sketch
6) Finish sketch
7) Click on "Decal" command
8) "Image" - click on inserted bmp
9) "Face" - click on face of part as desired
10) Wrap and chain to go around edges and bends
Experiment till you get it - works great!!
Mark Triton
news:31CF3EFDBEBF849ECAD9D2BCCF783773@in.WebX.maYIadrTaRb...
> thanks again Sean
then
> > Sean Dotson, PE
my
> > .bmp
> > > Brian Land
> > > Mechanical Design
> > > Lorik Tool Inc.
Message 5 of 11
When I put the .bmp file in the sketch, the file name is also shown below
the image. How do I get this to not show?
"Mark Triton" wrote in message
news:A73599537F24B483913AFFEF03F4225C@in.WebX.maYIadrTaRb...
> 4) Find bmp
> 6) Finish sketch
> Mark Triton
> > thanks again Sean
> then
> > > Sean Dotson, PE
> my
> > > .bmp
> > > > Brian Land
> > > > Mechanical Design
> > > > Lorik Tool Inc.
Message 6 of 11
Try this and see if it helps
If you are comfortable editing the registry you can try this. If you aren't familiar with
editing the Registry I would advise against it.
Start the Registry Editor and locate the following key:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionX.X\Translators\
SatTranslator
Create a new DWORD entry named SaveACISVersion and enter a value of 2, 3, 4,
5, 6 or 7. The value you enter represents the ACIS version used when you
export to the ACIS file format:
For example, if you enter a value of 5, an ACIS version 5 file is created
when you export to the ACIS file format.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Kirk A." wrote in message
news:75DF54EA78CC65B8D5C3E133F7F453D2@in.WebX.maYIadrTaRb...
Message 7 of 11
or see the latest FAQ 🙂 (ha I finally got Kent on another way to skin the
cat)
Sean Dotson, PE
"Kent Keller" wrote in message
news:6239DD4DCE5C0FF9A3A9A3F09BC78CE0@in.WebX.maYIadrTaRb...
> SatTranslator
4,
> Kent
below
Message 8 of 11
wait a second.. Kent you posted the wrong registry hack...
Sean Dotson, PE
> SatTranslator
4,
> Kent
below
Message 9 of 11
Do'h I am still learning how to use that cut and paste tool Ok so go see Seans
FAQ. 8^))
Kent
news:5D319DA28E42319D4FFA5A393BB72800@in.WebX.maYIadrTaRb...
Message 10 of 11
FYI - I created a block with 4 decals wrapped around sharp edges. I then
filleted a couple of the edges. The decals involved split in half as
expected. I then re-ordered the affected decals (dragged them down after
(below) the fillet in the browser) and they recreated perfectly around the
bends!!! If anyone would like to see it, I can place a copy of it up on CF.
Mark Triton
E/M Packaging Designer
World Precision Instruments, Inc.
Sarasota, FL
Message 11 of 11
That's good! I'd expect the first part of the behavior as well but I'm glad
to see it healed itself after the reorder...
Sean Dotson, PE
news:B34EE43B62CB291D539D5DDAFB492E14@in.WebX.maYIadrTaRb...
CF.
> Mark Triton
> Sarasota, FL
