Hello all
I am taking a chair that i have and trying to make a 3d model of it on Inventor.
The problem that i have is this has many riduclous curves and concaves. I wanted to know if their was such a tool that would help me with this, like a sculptor tool or something of that nature that will help me make a smooth 3D cuvry figure.
I attached pictures of the chair to this message if that helps.
Thank You in advance
Hi
See attachment for exemple
That doesn't look so hard?
There are several curvy stuff tutorials in my signature.
You might start with the Vacuum.
@Anonymous wrote:What does the vacumm do?
Brandon
Teaches you how to generate complex curved surface.
With that knowledge you should then be able to create your chair (similar process used for the car seat I posted).
You copy and paste the url in my signature into your favorite browser.
This will take you to several curvy stuff tutorials.
Look for the Vacuum tutorial.
It should take you here -
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
Okay, I have the pdf
Can you please send me the example file for the vacuum that is mentioned in the pdf?
Thank You,
Brandon Herrera
@Anonymous wrote:Can you please send me the example file for the vacuum that is mentioned in the pdf?
Brandon Herrera
How does it say to obtain this file at the bottom of page 1 on that tutorial?
The reason i asked for it is because I do not like giving out my email for security reasons but since you want me to, i sent you an email already
Thank You
