Inventor Forum
curvy chair help
9 REPLIES 9
Message 1 of 10
brandonherrer14
1112 Views, 9 Replies
curvy chair help
Hello all
I am taking a chair that i have and trying to make a 3d model of it on Inventor.
The  problem that i have is this has many riduclous curves and concaves. I wanted to know if their was such a tool that would help me with this, like a sculptor tool or something of that nature that will help me make a smooth 3D cuvry figure.
I attached pictures of the chair to this message if that helps.
Thank You in advance
9 REPLIES 9
Message 2 of 10
yannick3
in reply to: brandonherrer14
Hi
See attachment for exemple
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 3 of 10
JDMather
That doesn't look so hard?
There are several curvy stuff tutorials in my signature.
You might start with the Vacuum.
Message 4 of 10
brandonherrer14
in reply to: JDMather
What does the vacumm do?
Brandon
Tags (1)
Message 5 of 10
JDMather
Brandon
Teaches you how to generate complex curved surface.
With that knowledge you should then be able to create your chair (similar process used for the car seat I posted).
Message 6 of 10
brandonherrer14
Is the Vacuum a tool?
Where do i acess it because i have not been able to find it.
Thank You
Brandon
Message 7 of 10
JDMather
You copy and paste the url in my signature into your favorite browser.
This will take you to several curvy stuff tutorials.
Look for the Vacuum tutorial.
It should take you here -
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
Message 8 of 10
brandonherrer14
Okay, I have the pdf
Can you please send me the example file for the vacuum that is mentioned in the pdf?
Thank You,
Brandon Herrera
Message 9 of 10
JDMather
Brandon Herrera
How does it say to obtain this file at the bottom of page 1 on that tutorial?
Message 10 of 10
brandonherrer14
The reason i asked for it is because I do not like giving out my email for security reasons but since you want me to, i sent you an email already
Thank You
