Inventor General
Valued Contributor
Terry__Close
Message 1 of 7 (481 Views)
curved bend in sheet metal part
481 Views, 6 Replies
12-26-2012 01:18 AM
Hi
Can a curved section with bend be applied to sheet metal part.I make extrusion for easier clarity.I am wanting to place the curved section (extrusion for demonstration purpose) with bend in sheet metal part but all created in the sheet metal environment.
Is this possible?
TC
Message 2 of 7 (465 Views)
Re: curved bend in sheet metal part
12-26-2012 04:53 AM in reply to: Terry__Close
Use Contour Roll.
I would do the rolled feature first.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Terry__Close
Message 3 of 7 (436 Views)
12-27-2012 04:10 AM in reply to: Terry__Close
OK
I did some searching and came up with the attempt attached.Have i done this correctly?
CAn this part now be flattened?
I do not use sheet metal that often but will make efforts to learn more
Terry
Valued Contributor
Terry__Close
Message 4 of 7 (407 Views)
12-28-2012 07:00 AM in reply to: Terry__Close
pls see attached
can this part be flattened?
Message 5 of 7 (382 Views)
12-30-2012 06:09 AM in reply to: Terry__Close
I have not attempted your part yet, but after seeing your attempt I wish to revise my earlier statement.
Looks like if this is to work the Contour Roll should be created after the Face.
Valued Contributor
Terry__Close
Message 6 of 7 (338 Views)
01-01-2013 06:44 AM in reply to: Terry__Close
JD did you attempt to model this please.Would like to see correct solution
Terry
Valued Contributor
Terry__Close
Message 7 of 7 (224 Views)
01-08-2013 04:55 AM in reply to: Terry__Close
OK i have placed the Contour Roll after the face but still does not flatten.What am i doing wrong here?
Terry
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
