Inventor Forum
creating a wire mesh
8 REPLIES 8
Message 1 of 9
leandrav
28105 Views, 8 Replies
Can anyone give me a solution as how best to go about creating a "wire mesh".
What i have tried is to create a solid flat (2mm thick) piece of material.
I then draw a diamond shape on the surface & extrude it so as to give me a void.
Then i use the rectangular pattern option.
The problem is that when i try putting in the amounts of the "holes" i need to brings up  message to use optomized compute.
I do that and then when i click to crate all the "holes" it comes up with a pattern failiure error.
What other way can i use to create my object.
8 REPLIES 8
Message 2 of 9
stephengibson76
in reply to: leandrav
depending on what you are doing it might be worth using a wire mesh texcture rather than trying to model it which will be really heavy in terms of computing
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 3 of 9
You will want to use a texture, becasue creating a rectangular pattern of a cut-out will cause extreme lag in your system.
I found that the textures are scaled low, so they don't show up well, but follow this old post and it should help you get your result.
Old Post
Message 4 of 9
leandrav
Awesome!!! works beautifully
Thanks for the help guys!!
Message 5 of 9
BLHDrafting
Here is a more realistic Wire Mesh part. Just change the 4 User parameters to suit your needs. It's not overly taxing on the model. Can't remember where I found it but it's handy and you can 'bend' it.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Message 6 of 9
leandrav
in reply to: BLHDrafting
I will give it a try. Thanks
Message 7 of 9
savich
Thanks, this works great!
Message 8 of 9
MelHoward8999
worked for me
Message 9 of 9
jaskiratVPK8U
This is really nice part. Thank you for sharing.
I have one more question. How did you put function in the description of the part. See the attached screenshot.
