I need to create about 100 off points in a sketch.
I have the x and Y co-ordinates in a excel spread sheet. Is there any simple way to create the points other than manually entering thru precise input.
Any help would be much appreciated.
Thanks.
Solved by MariaManuela. Go to Solution.
Create a new 2D sketch.
Go to Insert Points
Select XLS with XY coordinates
Go to Import Options to create automatically a a Line or Spline through points (if needed).
