Inventor Forum
create part list drafting
2 REPLIES 2
nicu_bogd
345 Views, 2 Replies
hello. i insert into ISO.idw an assembly which contains some parts and another assembly. when i create the Part List table it shows only those parts and the subassembly. how to display all the parts from that assembly and subassembly?
Tags (3)
2 REPLIES 2
Cadmanto
in reply to: nicu_bogd
If you open up your subassembly and go to the Bill of Materials tab inside of the Document settings, you need to change the setting to Phantom.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-A0A95805-CBF6-4524-8314-4AC8B53C19CF
This will allow the components of that subassembly to appear in the upper level partlist like you are trying to show.
Hope this helps.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
nicu_bogd
It works. Thanks
Before this, I found another way to show all parts from the assembly. After I click on Part List button into ISO.idw appears a window. In that window I choose the option Parts only (legacy) and then I select the view. And It shows all components of assembly, subassembly and so on 🙂
