I was just wondering if there is an easier method of getting a 45 degree corner on flanges of 2 different sizes.
1 flange is 1" and the other is .75". I have been cutting the .75" flange down and adding to the face of the 1" flange.
The corner I'm talking about is on the far right of the part.
Dean
Solved by Curtis_Waguespack. Go to Solution.
Hi feldmanncad,
If you set your flanges to use the Width option rather than the Edge option and then create them one at a time, you can then use the Corner Seam tool to pull them together. Attached is an example file.
I hope this helps.
Curtis
Wow. That's a lot easier and quicker than my method. Thanks a lot Curtis.
