Guys,
I have just completed an assembly and in this assy. I have a tube and pipe run. The original frame holding this pipe was 1m*1m*2m. We are now building a smaller unit with the same design. The pipe run is exactly the same except for the pipe diameter.
I tried to save as the pipe run to a new name and change pipe diameter but it gives me this error seen below. Do I have to make the whole run again? If i change run I have now to what I need for smaller frame I lose original sizes for first frame size.
I hope this makes sense!!!!!!!!!!!
Cheers
Michael
Problems encountered while saving the document.
Save failed because the following files have been modified and must be saved together with Cooling_Skid_Type_I.Tube and Pipe Runs.iam: Cooling_Skid_Type_II.Run01.iam,Cooling_Skid_Type_II.Route01.ipt,Cooling_Skid_Type_II.Route02.ipt,Cooling_Skid_Type_II.Route03.ipt,Cooling_Skid_Type_II.Run02.iam,Cooling_Skid_Type_II.Hose01.iam,Cooling_Skid_Type_II.Hose01.ipt
Use these steps that came from the Routed System training manual I created for our designers.
Will this also work if you have a completed first iam with mutiple runs that you do not want to change ever and you want to have the exact same runs as first iam in another iam but will be adding more to the new iam. I do not want the first iam to change, but want to use it as a starting point for a new iam. When I edit in the new second pipe iam it will change in the first iam as well. Will the process above take care of that issue?
