When I try to copy design from Vault, but I cannot do it, here the message.
Andy
Solved by Andy_Kuang. Go to Solution.
You need to be logged in as a vault administratoror or content centre administrator to copy within vault. Are you stand alone or networked if you are standalone you should have access to an administrator password. If you are networked you either need to talk to your administrator or obtain an administrator password. (a more complex solution if you are standalone is to edit the vault access rights, but if you are at all unsure of what you are doing leave well alone)
Maybe the problem is that a part used in the drawing/assembly that you are trying to copy design of is checked out?
Expand the details... what does it tell you?
What version of Vault are you running?
Thanks for your answer, I'm running Vault 2012,
When I expand the details, and I found the problem.
I set the correct Inventor Project file, now I can perform the "copy design.
