I´m importing a parasolid text file created in inventor into ANSYS 13 and I can import the solid sucessfully. The problem is that I need to see the geometry code (keypoints, lines, areas, volumes) in order to run optimization on ANSYS 13.
Do you know how to convert parasolid text files or any CAD format into ansys programming language (ADPL) text file?
