I apologise if this has been covered in a previous posting, but I did not find a "clear" answer.
As a background....I am coming off of 10+ years using Catia (that's the software the company used) and have moved to a company that uses Inventor instead. I have used inventor for the past year.
In the past (Catia) it seemed pretty intuitive to create the vertical and horizontal during the creation of the sketch in such a way that would reflect the way you would want it defined as a view in a drawing. As well as controlling the preferred screen view (vertical +’ve to the top of the screen and horizontal +’ve to the right of the screen)
As per a previous post....I have tried the "Edit Coordinate System" but find it difficult to control the Vertical and Horizontal axis independent of each other.......
I understand that "functionally" there is no issue...but it becomes quite disorienting in a complex model when going to edit a sketch and the model spins around, showing the sketch in an orientation that doesn't relate to the models features, or "sketch related" features.
It becomes especially difficult/confusing when modifying/checking other peoples models as well.
I just wanted to support the need for this functionality. In the end it just enhances the flexibility of the software and maintain some amount of definable company standard work procedures for modelling.
Maybe it hasn't been included in the software because of proprietary reasons? I would hope there is a reason.....it seems like there are people out there who would utilize it.
@Anonymous wrote:....I have tried the "Edit Coordinate System"
...when going to edit a sketch and the model spins around, showing the sketch in an orientation that doesn't relate to the models features, or "sketch related" features.
1. I have never used Edit Coordinate System in Inventor.
2. Turn this spinning off. Tools>Application Options.
