I have a read write library set up and have copiued several families of fasteners into it so I could assign company specific part numbers to them. I haven't added any new families to it in quite a while but I have a need to add a new family to the read/write library. However, when I try ti copy a family to my custom read/write library it fails with a rather generic error "a copy of the family Hexagon Socket Button Head Cap Screw - Inch can not be created in the library <filrname>."
I have used this feature before but now it won't work. I have administrator privelages.
I can't even seem to edit existing families previously copied int my custom library. I know it must be some kind of permissions issue but can't figure it out.
When I try to modify items in one of my old families I can change a field but when I click on the apply button it comes back and tells me "Failed to publish to selected Library."
Any help with this would be appreciated.
BTW:
Inventor2009 - yes I know but its what the company has and dowsn't seem in a hurry to upgrade.
Yes, all was done in INV2009. I was still able to place items from the libraries. The libraries are stored on the ADMS machine which is a remote machine rather than on my local machine.
I have resolved the issue by detaching the library and reattaching the library. I'm not sure why this happened but it does annoy me. It seems that every time microsoft updates the windows operating system something else bad happens with inventor or vault. I suspect it has something to do with shared dll's. I wish Autodesk would build an application that is not so dependant on third party files to run.
Thank you Mark for your reply.
Windows updates can wreck havoc with Inventor and/or Vault at times. I've gotten into the habit of manually installing all updates so that if I run into problems I can uninstall them just as quickly.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hello all,
We just upgraded? to Inv2015 from 2009. Everything is very different with the ribbons and all and trying to figure out where everythiong is.
However, My immediate issue is that when my reseller came out and did the migration they moved my content center from and old network drive to the new Vault machine. My custom libraries are accessable and I can insert content center parts int assemblies etc but when I open existing assemblies that use content center parts such as nuts and bolts the vault browser shows the red dot that indicates the local file is out of date and that I should use the refresh file, that the file has been renamed of moved.
Well yes it has but it is my understanding that when you place a part from a library file the location is hardcoded into the file. The original file has an instance on my local machine, thats where I'm guessing the assembly gets the part but the project points to a different location now.
How can I get thousands of nuts and bolts in hundreds of assemblies to use my custom library content center parts from the new location? All the nuts and bolts have had the descriptions and part numbers changed so they make sense to us on parts lists and assembly drawings.
I'm sure I'm not the only one to run across this.
Thanks in advance for any help.
Stupid question maybe, but is the custom library set to Read-Write in the project file? Sometimes I'll have a fit of caution and set my custom libraries back to Read Only to make sure I don't break anything when I'm having an attack of the stupids, and then later I'll forget that I've done it and beat my head against the desk trying to figure out why I can't make changes to anything.
Rusty
