hi guys,
i'm italian so sorry for my bad english... i drew a cylindrical cam using the inventor tool then i also drew the actuator ( a simply plate rounded on top) but when i add the contact tangency link between the two surfaces and i move the cam , the two objects interpenetrate! Some one can help me to find the solution?
Raffaele
P.s:
i'm using inventor professional 2012
Solved by imbik. Go to Solution.
Hi
Without seeing the files, I can't help, but try this.
http://inventor-tales.blogspot.com.au/2012/10/using-transitional-constraint-in.html
hi ,
i tryed to draw a good example to help you to understand what is the problem..
so i draw this :
http://imageshack.us/g/849/camma1.jpg/
ps.: i used the transitory contact. and if i draw a pin instead the parallelepiped it works!
I do not know what solutions and/or possibilities you have already tried, nevertheless I had a similar problem couple of weeks ago, ironically the solution was simple. You can find the details in the following topic;
http://forums.autodesk.com/t5/Autodesk-Inventor/transitional-please-help/m-p/3138614
What valued mentor "coreyparks" suggested me was to use a sphere in stead of the surface of the follower, and it worked. I have created an hollow sphere at the same heigth with my follower and used tangent feature between the sphere and the cam surface. I have also attached a picture about what I did.
I hope it helps
