Inventor Forum
constraint question
4 REPLIES 4
154 Views, 4 Replies
constraint question
I am drawing an assembly of a spring loaded ball plunger.
When I insert the ball into the housing, what type of constraint should I use to ensure the ball protrudes .048"
from the housing.
4 REPLIES 4
You'll need to use some workplanes on the ball and
the socket.  Then use mate-mate on the ball and socket's workplanes.
(You can even get fancy then make them adaptive to have the ball retract when
necessary <g>)
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
When I insert the
protrudes .048"
from the housing.
OK. Got it. One more constraint question:
How do I constain 4 slotted holes to 4 shafts and centered on the slotted hole?
Thanks Bill
Make two workplanes bisecting each slot in each
direction.  Now put a axis through the planes (it's now perp to your
surface).  Now mate-mate the axis to the shafts.
Sean Dotson, PE
Check the Inventor
OK.
Bill
When I draw the slot I usually have some type of point in the center of the sketch I extruded. A workpoint or the end of a construction line. After I extrude the slot I turn the sketch visibility on and create a work axis by selecting the sketch plane and then my center of the slot (the 2D sketch point). I then turn the sketch visibility off. - Rich Thomas
