Inventor General
Member
keith.skidmore
Message 1 of 3 (122 Views)
Accepted Solution
constraint issue
122 Views, 2 Replies
05-04-2012 07:11 AM
Hello
While creating an assembly I will mate components together to a grounded component and the assembled parts are allowed to be moved and or rotated.
To get them back into position I need to click re-build.
Previously once you mated parts together I was unable to move or rotate them (they would become anchored)
Have I in-advertently changes a setting? And if so how do I get it back?
Thanks in advance
William K. Skidmore
White Conveyors Inc.
*Expert Elite*
cwhetten
Message 2 of 3 (113 Views)
Re: constraint issue
05-04-2012 08:10 AM in reply to: keith.skidmore
Are you using the Move command to move them, or are you just dragging them?  The behavior you describe is normal behavior if you use Move to drag a component.  However, it is not normal behavior for simply dragging a fully constrained component.
Employee
johnsonshiue
Message 3 of 3 (96 Views)
05-04-2012 01:06 PM in reply to: keith.skidmore
Hi! It sounds like you might have turn on Defer Update in the assembly. Please go to Tools -> Application Options -> Assembly -> uncheck Defer Update.
If it does not help, please post the files you are having trouble with here or send them to me.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
