Inventor General
Active Member
Message 1 of 8 (310 Views)
constraining and assemblies
310 Views, 7 Replies
12-28-2012 05:42 AM
I need to have one assembly constrained to three places on along a bar. Should I ( and how would I?) open another assembly drawing, insert said bar and some how  insert those three assemblies into the drawing?
Message 2 of 8 (306 Views)
Re: constraining and assemblies
12-28-2012 05:55 AM in reply to: topher5150
I may be wrong, but it sounds like you are confusing drawings with assemblies.
Try starting a new blank assembly. Insert the bar and then insert 3 copies of the assembly.
Constrain them to the bar in the positions you require and save this new assembly.
Open a new drawing, select the newly created assembly for your base view, and proceed accordingly.
Again, I may be wrong, but I hope this helps.
Autodesk Product Design Suite Premium 2013
Inventor 2013 64-bit Edition
Win7-64, 8-core Intel® Xeon® CPU W3550 @ 3.07GHz
NVIDIA GeForce GTX 560 Ti
454 GB HD, Intel® ICH10R SATA AHCI Controller
SpaceNavigator, 3.14.2 / 6.14.0 / 3.18
Active Member
Message 3 of 8 (261 Views)
12-31-2012 08:19 AM in reply to: CrAzY-MiKe
Is there a way to constrain something so it's 90 degrees perpendicular
Message 4 of 8 (258 Views)
12-31-2012 08:26 AM in reply to: topher5150
Up in the Ribbon, in the Constrants box you should find a Perpendicular constraint button which looks like an almost upsidedown "T". Click on this button, then pick a face (side) on the bar and a face (side) on one of the assemblies that you want to be perpendicular to each other.
*Pro
sbixler
Message 5 of 8 (221 Views)
01-01-2013 07:09 AM in reply to: topher5150
I'm sure there's a way, but without pictures or files, we can only guess.  But first tell us what context you're working in: sketch? assembly? part features?
Message 6 of 8 (197 Views)
01-02-2013 04:56 AM in reply to: topher5150
topher5150;
Do you have access to the tutorials that usually accompany an install of Inventor? If so, you should try the ones concerning Assemblies and the constraints therein. If you follow the instructions carefully, I believe you will find them instructive and even fun!
Active Member
Message 7 of 8 (176 Views)
01-02-2013 07:08 AM in reply to: sbixler
I'm having trouble posting pics on here, but I am working on making an assembly. I am trying to constrain one assembly to a set of parallel beams so that the assembly will be 90degrees to the beams.
*Pro
sbixler
Message 8 of 8 (169 Views)
01-02-2013 07:27 AM in reply to: topher5150
Can't give you details without seeing your parts & assembly, but you can use the angle constraint between faces or workplanes/origin planes and set it to 90°.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
