Inventor General
Member
Message 1 of 2 (105 Views)
constraining an assembly to one motion
105 Views, 1 Replies
11-12-2013 11:39 AM
When I rotate the drive shaft gear very slowly, the assembly follows the the correct motion path, (figure 1), however, when I rotate it quickly, the assembly snaps the linkages to an orientation that is not physically possibe, but satisfies the geometrical constraints (figure 2).  I can't use contact solver because I am using the adaptive function for my sub-assembly to avoid having to re-constrain many parts.
*Expert Elite*
Message 2 of 2 (79 Views)
Re: constraining an assembly to one motion
11-12-2013 01:13 PM in reply to: bahorton
It is usually better to impart motion with Drive Constraint (or in the Dynamic Simulation environment) than by dragging with mouse.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
