Inventor General
Valued Mentor
RayFeiler
Message 11 of 15 (890 Views)
Re: constraining a hole to a slot
03-26-2012 08:22 AM in reply to: folkman1
Try this one. Are you on Inventor 2012?
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
JDMather
Message 12 of 15 (885 Views)
03-26-2012 08:27 AM in reply to: mcgyvr
mcgyvr wrote:
Its as simple as it gets now..
Creating as iFeature (I use as Punch even if not sheet metal) make it as easy to place and size as any Hole feature.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Doug_DuPont
Message 13 of 15 (876 Views)
03-26-2012 08:59 AM in reply to: folkman1
What I do is on my slot sketch I have a center point. When I constrain I turn on the slot sketch and constrain the hole to the center point in the sketch.
Douglas DuPont
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
markc-uk
Message 14 of 15 (837 Views)
03-27-2012 03:46 AM in reply to: Doug_DuPont
It's good practice to put a workaxis at the centre of any slot. Try this workflow that's detailed in the animated .gif attached for a tidy way of placing the axis.
edit - you need to save it then right click on it and open with Internet Explorer
JDMather
Message 15 of 15 (817 Views)
03-27-2012 05:54 AM in reply to: markc-uk
An extruded surface body cylinder in effect creates an axis with less work and more functionality (Insert constraint now available).
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
