Inventor General
Valued Contributor
Terry__Close
Message 1 of 6 (200 Views)
connector + hose
200 Views, 5 Replies
11-16-2012 05:57 AM
Is there another way of doing this other then using the pipe and run tools.There are 6  x 10mm connectors.I want to run 10mm plastic tube from the bottom 3 connectors up to the top 3 connectors.Please how can this be done other then using pipe and tube tools?
Regards
Terry
By the way is this simple if using the pipe and run tools?
Valued Contributor
Terry__Close
Message 2 of 6 (172 Views)
Re: connector + hose
11-17-2012 04:37 AM in reply to: Terry__Close
Is this only achievable by using the Tube & Pipe tools?
Terry
Message 3 of 6 (167 Views)
11-17-2012 05:35 AM in reply to: Terry__Close
If you don't want to use Routed Systems then simple start a new part in the context of the assembly.
Project Geometry a connection point (like a circle or similar) from each connector.
This will make the new part adaptive to the position of the connectors.
Create 2D or 3D sketch for your tube run and Sweep.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Terry__Close
Message 4 of 6 (162 Views)
11-17-2012 05:40 AM in reply to: JDMather
Thanks...i`m new to what you suggest...could you give an example of how you would do this or could you add the hoses to the conectors i attached in my first post...
Is there any difference between the way you explained to do this and the Routed system.
Message 5 of 6 (158 Views)
11-17-2012 06:08 AM in reply to: Terry__Close
This is basically what Routed Systems does - but it has tools that automate the process so that it is fewer steps.
The attached was done in student version - so keep separate from your data and delete after examination of technique.
1. Turn on or create connection point in Connectors (I used origin Center Point and logical axis).
2. Create New Part in assembly. (set to constrain to connector part)
3. I like to then exit part and add second constraint to axis of new part and connector.
4. Edit the part and start new sketch and Project Geometry for the tubing profile.
5. Start a 3D sketch and Include Geometry the connection points at both ends of tube.
6. Create lines for straight sections of tubing (if all will be straight I might do these in 2D sketches instead, depending on how tightly I need to control the location).
7. Connect the 2D lines (in my simple case attached) with spline, including as many points in space as needed to control the path (if this is bent tubing I do slightly different with Bends between straight line sections).  Add tangencies to lines at start and end.
8. If you need additional point to the spline you can add them.  You can use the 3D Move/Rotate tool to move points as needed.
9. Sweep the profile.
Repeat as needed.
Valued Contributor
Terry__Close
Message 6 of 6 (137 Views)
11-17-2012 04:39 PM in reply to: JDMather
Thanks JD
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
