Hi
I'm stuck with the appropriate term to use for concatenate physical property, exemple, if i want use a custom property to merge mass, density and volume and I did not find the term to concatenate them. ex: Physical property =<Mass> lbs <Density> lb/in³ <Volume> in³ someone at autodesk can post here or on the help a list of all terms (sheet metal properties and Iproperties)
I do not have knowledge of these specifically and someone from the QA or Development side would need to comment here.
Don
