Solved by chris30. Go to Solution.
Not exactly sure what information you are after, but -
Open the ipt file and switch from Assembly View to Modeling view.
We're trying to extract things like:
Wire Diameter
Pitch
Load
Etc....
Things from the dialog used to generate the spring.
(I have a spring in an assembly, but no record of the data used to generate the spring.)
@CHriS wrote:
Thanks for the help. As always, as soon as I ask for help, I find the answer.
So what is the answer?
