Inventor Forum
compress spring
8 REPLIES 8
Message 1 of 9
2716 Views, 8 Replies
compress spring
Please how do i get the spring to have a compressed look with flat end....i try different settings but not able to have the spring rings to touch for a compressed look
Regard
IJC
8 REPLIES 8
Message 2 of 9
anyone please
Message 3 of 9
blair
You should probably be modeling this as a IAM assembly file:
http://www.youtube.com/watch?v=O2XVbE26BNM
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 9
Thanks Blair
Good video
I will make this part as a IAM....i actually want the Spring in a static compressed position....i cannot get the rings though to touch as if the spring is compressed
IJC
Message 5 of 9
blair
If they are touching, this would then be a self-intersecting sweep and Inventor will through up an error. Improvements to this have been made in IV2014 but you really should model it then with a very small gap between the coils if this is your goal.
Delta Tau Chi ΔΤΧ
Message 6 of 9
glenn-chun
Hello IJC, open the attached part and change the pitch of the coil.  I split the coil profile in half.  What value did you want for the pitch?
Glenn
Glenn Chun
Sr. Principal Engineer
Message 7 of 9
Hi Chris
I am trying to follow your modelling...how did you split the coil in half...i do not see a split
IJC
Message 8 of 9
sorry i meant Glenn
Message 9 of 9
glenn-chun
Hi IJC,
I used the Center Point Arc command to draw two 180-degree circular arcs and then deleted the original full circle.
FYI, I'm attaching the Self-intersecting coils section of the What's New in Inventor 2014:
I'm curious to know what value you wanted for the pitch to "get the rings though to touch as if the spring is compressed".
Glenn
Glenn Chun
