hi, i need help..
i was searching for a way to change the color of the project geometry,,
i've found this via the cad setter out
i have install the color scheme editor
i did a backup of the registry using the reg export and save it elsewhere in my cpu
i've made one change to a color then it save
when i open inventor all the color scheme are messed up...
i was using winter night...and now my background color is green....in the part/assembly environement as well as in the drawing environnment...
i've try reopening the color scheme editor, fisrt it wont stop showing error message.. and even after i import the reg back up i've made and the change i've made is back to what it was before
i still have the green background...
i've also try to repair the program witch change nothing..
before reinstalling what can i do
please help
same problem and search for some hours on internet for a way how to fix it.
what it helped me was a czech forum and chrome from google ( which is automatically translating from any language to english )
and it was much easyer than I thought.
export your seting from inventor option menu ( so you can use them again ) , export your customized ribon / keyboard / making menu ( if you have any customize comands )
then hit the "windows key" on your keyboard , type " reset inventor " chose right version ( in mine case 2018 )-> click on reset and restart invenotr ( assuming that you have closed invenotr after exporting all menu's )
https://www.cadforum.cz/forum/forum_posts.asp?TID=26512&title=inventor-color-scheme-editor-problem
