I have a new employee who is color blind. I searched the forum and was unable to find a solution for version 9 Inventor. The colors in sketch mode are a problem as well as the colors in the pick boxes for certain commands. Specifically the red arrows in the pop up command boxes.
Thank you in advance.
I am not sure if Inventor 9 has this, but Inventor releases do come with an add-on in the SDK folder called Inventor Color Scheme Editor. You can control the color of every single entity. It should be located here:
For XP - <Inventor install folder>\SDK
For Vista / 7 - C:\Users\Public\Documents\Autodesk\Inventor <version>\SDK
If not you may be able to download it directly somewhere but I am unsure...Hope it helps.
Ocean Blue color scheme is available for v9 at http://teknigroup.com >> Downloads
