Inventor Forum
coincident constraint
3 REPLIES 3
jones311
8141 Views, 3 Replies
A few days ago when I would draw a C-channel, i was able to just draw it and extrude it but now when I try that it does not work.  I have to use the coincident constraint every time I draw something using the line command in Inventor 2012. Is there an option I accidentally turned off that it is making me use the constraint every time?
A file with a c-channel shape is attached, try the offset and extrude command to see what I am talking about.
3 REPLIES 3
Hi jones311,
You've likely toggled off your constraint inference and/or constraint persistence buttons.
This link from Paul Munford covers it:
http://cadsetterout.com/inventor/temporarily-turn-off-inferred-constraints/
 Or you've turned off the inference for just the coincident constraints.
Check this by right-clicking while in a sketch and choosing Constraint Options:
http://forums.autodesk.com/autodesk/attachments/autodesk/78/331399/1/112145.GIF
I hope this helps.
Good luck with all of your Inventor pursuits,
Curtis
http://inventortrenches.blogspot.com/
jones311
in reply to: jones311
Hey Curtis,
My constraint options was the problem, I must of unchecked all of the constraints at some point  but that fixed my problem.
Thanks alot for the help.
PaulMunford
Thanks for the link Curtis 🙂
I hope that it helped you out Jonesy!
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
