Inventor General
JDMather
Message 11 of 15 (491 Views)
Re: changing sketch orientation
10-13-2011 08:18 AM in reply to: swalton
I never worry about it.
Most of the time I start out a sketch (2D) from a 3D perspective as I live in a 3D world and that is how I think.  (in fact it irritates me when Inventor swings around to a parallel view when starting a sketch and I have to nudge my Space Navigator to get back into a 3D perspective on what I am modeling.)
Once I have a few enitties I might clcik on the glass cube and rotate if needed to finish up the sketch from a 2D perspective.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
swalton
Message 12 of 15 (483 Views)
10-13-2011 08:30 AM in reply to: JDMather
Functionally, I agree with you.
In IV we don't care either, because it is too cumbersome to control.
But, in ProE, where the company owner/head engineer will review your work, and he wants up to be up in each sketch, we care.  He signs the paychecks.  :smileywink:
Inventor 2014
Vault Professional 2014
JDMather
Message 13 of 15 (476 Views)
10-13-2011 09:04 AM in reply to: swalton
swalton wrote:
But, in ProE,
Show him Ctrl Wheel in Pro.
My sketch is going to be oriented correctly relative to the rest of the model - no matter what plane I select as Reference.
Employee
udayag
Message 14 of 15 (473 Views)
10-13-2011 09:23 AM in reply to: icreator3d
One possibility is to have a customized part template with two additional workplanes (named, say, "my XZ Plane", "my YZ Plane").
To cretae "my XZ Plane", first create a sketch using the "XZ Plane". Then using the "Line" command first pick the origin point (point A), then pick a second point (point B) so that AB is vertical. Note that AB is parallel to the Z axis. Pick a third point  (point C) so that C is to the left of line AB. Now create a workplane based on 3 pounts and pick the points A, B, C in that order. Rename this workplane as "my XZ Plane". DElete the sketch you created earlier without deleting the dependent workplane. You could create  "my YZ Plane" similarly.
Any sketch based on these workplanes will be oriented the way you desired.
Save this part file in the template folder with an appropriate name.
Udaya Gunasena
Fusion Development
Patrickwesc
Message 15 of 15 (226 Views)
03-28-2014 07:31 AM in reply to: JDMather
Let me guess, you're a cut, extrude and mate kind of guy.......
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
