Inventor Forum
center line to edge
5 REPLIES 5
190 Views, 5 Replies
center line to edge
When putting in a centerline, I can edit the line and get it to align with
an edge. This is good. Now if I use that centerline to create a dimension,
say an angle to a hole, the centerline looses its alignment to the edge. I
can go back and edit the centerline and align it to the edge again, but what
ever I do to the dimension will cause the centerline to loose its alignment
to the edge. Is there a fix? (Or, sarcastically, do I have to by Pro?)
5 REPLIES 5
I can't say that I've ever tried that. A possible work around is to create a view sketch (NOT a sheet sketch) and create your line through the center and parallel to your line that can be dimensioned.
Rich
This is in a IDW right? What is the centerline a centerline for? can you use a bisector
centerline or one of the other ones rather than sketching one in? Actually you don't even
say how you created the centerline?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Herb Morrison" wrote in message
news:1AB4A8E8EB318F0E4656F4363BF59F92@in.WebX.maYIadrTaRb...
Its in an idw, it is the a large bore hole with a bolt pattern around it. I
used the center mark tool and extended the center lines.
I found a work around.
"Kent Keller" wrote in message
news:E4777FF24D01FB64E35A0BC17D6F8E3D@in.WebX.maYIadrTaRb...
use a bisector
> Kent
> Assistant Moderator
with
dimension,
I
what
alignment
The centerline bisector Kent mentioned is normally used for bolt patterns,
have you already tried that? The icon is like two angled lines and an arc.
~Larry
news:5CECF534A71345BBAEBA3CECAEC44B0F@in.WebX.maYIadrTaRb...
I
you
> use a bisector
> > Kent
> > Assistant Moderator
> with
> dimension,
edge.
> I
but
> what
> alignment
Pro?)
Yes I have use that for other purposes, but not for a bolt circle.
"Larry Caldwell" wrote in message
news:820A225C261A13E5062DD4C76C159A9C@in.WebX.maYIadrTaRb...
> ~Larry
it.
> I
> you
> > use a bisector
> > > Kent
> > > Assistant Moderator
align
> > with
> > dimension,
> edge.
> > I
> but
> > what
> > alignment
> Pro?)
