Inventor General
Member
dash1982
Message 1 of 17 (2,925 Views)
cant open inventor 2011 undo folder message
2925 Views, 16 Replies
02-28-2011 06:54 AM
when i try to open my 2011 inventor program which ive been running for months now i get an error message. and the program refuses to open. "Error in Inventor Undo Folder: Please Make Correction" any ways to fix this so i can get back to work. and i should add that i am not a computer genius im a furniture designer. please help me out here
*Pro
Dennis_Jeffrey
Message 2 of 17 (2,920 Views)
Re: cant open inventor 2011 undo folder message
02-28-2011 07:01 AM in reply to: dash1982
Let's start with your system specifications See this for what is needed:
http://teknigroup.com/support/Inventor/Howto.html
Something else to check (if you can get this far. Open Inventor, go to tools >> Application Options without opening a file:
What do you see here under the general tab?
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Member
dash1982
Message 3 of 17 (2,917 Views)
02-28-2011 07:05 AM in reply to: Dennis_Jeffrey
like i said ive been running this program since it came out with no problems. and nothing has changed on my computer as far as system requirements go
*Pro
Dennis_Jeffrey
Message 4 of 17 (2,914 Views)
02-28-2011 07:08 AM in reply to: dash1982
Good luck finding an answer without providing information that is needed.
Employee
Hochenauer
Message 5 of 17 (2,892 Views)
02-28-2011 10:02 AM in reply to: dash1982
I did a search in the source code for Inventor. You should see a dialog, not just a Message box.
The Dialog should give additional information to fix the problem:
Current Undo Folder:
Undo Folder Status:
In order to help you with this issue, it would be best if you could post a screenshot of this dialog here.
regards,
Gerald
Gerald Hochenauer(gerald.hochenauer@autodesk.com)
Inventor Principal Software Engineer
Manufacturing Group
Gerald Hochenauer
Senior Principal Engineer, Inventor
Member
dash1982
Message 6 of 17 (2,889 Views)
02-28-2011 10:09 AM in reply to: Hochenauer
No worries guy I fixed it myself. Thanks for tryi g to help.
**Master
BMiller63
Message 7 of 17 (2,886 Views)
02-28-2011 10:10 AM in reply to: dash1982
would mind providing the solution, for the next person that finds your thread while searching for the same issue.
thanks
Employee
Hochenauer
Message 8 of 17 (2,885 Views)
02-28-2011 10:11 AM in reply to: dash1982
Please mark the thread as fixed then - no use spending time if there is no further need for help.
Thanks!
Gerald Hochenauer
adenm
Message 9 of 17 (2,768 Views)
03-21-2011 03:57 AM in reply to: BMiller63
Yes Dash1982,
I agree with this question, can you post the solution because I got the same error on a fresh installation of AutoCADInventor and I have  no idea how to solve this problem. I'd like to prevent that our users get this message
If possible I would like to change the path to a location where All Users have acces (for instance d:\Undo) but where can I configure this setting?
Best regards,
New Member
jane.hokans
Message 10 of 17 (2,521 Views)
09-29-2011 09:43 AM in reply to: dash1982
I am having this problem in our school district.  I believe it is related to roaming profiles.  I would like to know how to set the path for the undo folder to a place everyone will have access to.  Can anyone help?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
