Please could someone help me here
I have attached a pic of the problem. I have only recently started having this issue and have no idea why it would do this.
Solved by johnsonshiue. Go to Solution.
Did you change the model .... That's what I get after I change something in the model and go back to the IDW. It loses the connection point.
It's not really anything you did from what I saw. I've had it happen dozens of times. I just do what ccarreiras said, I just reattach the one bad point.
Mike
Well heres the thing.
That is the first time im dimensioning the part. I have tried clicking everywhere to get that 12 mm. I know about just reconnecting the dimension if I did have to change the model but in this case its involving first time dimensioning.
Everything else has dimension fine. There were 30 more sheets of parts that had no issues.
It says Linear ...did you change a hole?
Sometimes it snaps a dimension to a bad spot that's easy to connect ..vs a good spot that's harder to snap too ..
Can you post the files here for others to see ..unfixed ?
Hi!!!
When open the file, it ask for another part... The left part...
The top part is somehow connected with another parts... i open it, but in "unresolved" mode.
I think the part has some link problems, maybe that's why the drawing has also a odd behavior.
Try to break link's or something like that, and try again.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
this parts width and depth is controlled by another part but just delete that parameter and change the depth and width to static values.
Maybe it does have to do with the unfold refold. only thing I can think of now that you mentioned that.
Hi! This is a bug. It should work. For some reason, the drawing dimension cannot attach itself to the view edges associatively. I don't think it is related to Unfold/Refold. The same behavior exists as long as Flange2 is there. I cannot explain it. I am sending it to development for further review.
Many thanks!
