Inventor Forum
cannot dimension drawing views, HELP
9 REPLIES 9
Message 1 of 10
m.granata
819 Views, 9 Replies
I am using Inventor 2013.  For some reason I cannot dimension some of the model entities in the drawing views in an idw file.  I can retrieve the model dimensions but it is usually easier to create the dimensions I need in each view.  This is the first time I have had this issue.  What causes this?  I can select the line, curve, etc. when dimensioning but nothing happens.
After I think about it.  What I cannot dimension are lofts that I created with rails.  These rails were made up of lines and curves, not polylines.  How do I get the sketches for the rails I used for lofting to display in the drawing views so I can dimension those sketches.
9 REPLIES 9
Message 2 of 10
Cadmanto
in reply to: m.granata
Try restarting your computer or your session of Inventor.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
ampster401
by chance were these files created in something earlier than 2013?  If so, were they migrated up to 2013 or did you just open them?
Message 4 of 10
m.granata
Rebooted workstation, same results.  All files were created in Inventor 2013.  Including the idw template file.
Message 5 of 10
karthur1
update 2 installed?  Can you post the part or duplicate it on another part?
Message 6 of 10
m.granata
I need to install update 2.  I found a method that works, although it may not be the best.  In the model tree, select the appropriate model sketch, rt mouse click, select include.  I am then able to dimension the model sketch of the rails in the drawing view.  Thanks for your help.
Message 7 of 10
JDMather
I'm sure Autodesk would like to see this dataset.
Can you attach the files here?
Message 8 of 10
Mopico
Do you have "Edge Property Selection" set.  It should be the default, but stranger things have happened.
Message 9 of 10
m.granata
I will double check that.  But it is just the lofted bodies that are giving me this problem.  I figured out how to dimension the rails I sketched to guide the lofts in a drawing view and that is what is critical.  These lofts are fairly complex, at least from my experience.
Message 10 of 10
PaulMunford
Double check that the drawing view is perfectly plannar to the view.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
