Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
can some one help with assembly
6 REPLIES 6
404 Views, 6 Replies
thanks to one user i was able to finish the blade then i did the next peices on my own all good and dandy. till i try to put them together for the next peice that attaches to the end with the 2 prongs. the one peice inside the large peice and the pin that is in it is in the right place its just the blade wont go through the hollow spot and line up with the pin. the other dimond cut peice in the page goes on after the hole in the blade 11.11 mm from the back tip to the face of the box. any help would be greatful.
6 REPLIES 6
also with the pin i set the lenth to 9mm insted of 8mm.
rhasell
Hi
For anyone to open the assembly, you will need to attach all the parts as well.
Just looking at your contraints (Only thing that is available without the parts) you should perhaps look at going through some tutorials and preferably attend a course.
In my Opinon 'Angle' contrains should not take the place of 'Flush' and 'Mate'
You should not have to use dimensions in ALL your insert contraints, that immediately tells me that there is something wrong.
If you worked around the default workplanes, use those for contsraining parts, and use Mate and Flush instead.
Depending on the connection, a "Mate" - "Axis" and a "Mate/Flush midplane" is better than a "dimensioned Insert."
The more manual input you have in the assembly, the more things you have to change if and when the model changes, and more things can potentialy go wrong.
Reg
2024.2
Please Accept as a solution / Kudos
in reply to: rhasell
here are 3 of them
and here are the rest
rhasell
Hi Jacob
I have built you assembly, see attached, I have NOT changed a thing, all I did was add the work planes where the default workplane should have been. I then contsrained your assembly, except for the 11mm item, I am not sure where you want that?
Firstly, there are a lot of issues with you models, you need to learn to constrain the sketches properly, there is a lot of information available on the web.
Try your best to work around the default work planes, it makes life so much easier.
There are some issies with the Blade Holder part. (I only checked the first few extrusions and sketches)
Nothing is constrained, there are no horizontal/vertical contraints either.
The midplane "line" is not in the middle either. (the pin hole is off center)
The Fillet at the bottom of the holder, has an overlap, I was quite surprised the extrusion even worked, (Learn't something new)
Too many dimensions and not enough constraints.
The part can be reduced to a few extrusions and one or two fillets with a bit of practice.
Great attempt though.
Read lots, keep playing with the software, you will get better every day.
Reg
2024.2
hey thank you as i have been waiting for someone to pitty a poor soul such as myself i have been going over alot of things that you and others have said and am trying to better myself. haha not to bad for the first day i hope here is what i have done on my own
