Hi
Please exceuse my lack of experience just learning how to use autodesk inventor. I am working on tutorials for Y8 students, they are going to draw this mechanism they have already made in Tech, I have drawn this and cant sort the cam constraint out, I have put a transitional constraint on the edge of the cam onto the surface of the follower wheel but the cam wont rotate all the way round only on the circular part, as soon as the movement gets to the straight edges of the cam the movement stops working. i have tried using different parts of the cam edge for the constraint but to no avail, I know this is possible and quite simple but cant work it out
thanks
Tony
Attach the assembly here.
The CADWhisperer YouTube Channel
Hi rst.beedham,
I didn't see where you mentioned the version of Inventor you're using, but If you happen to be using Inventor 2011 without service pack 1, that might be the issue. There was a bug in the intiial release of Inventor 2011 that prevented translational constraints from working correctly. Service Pack 1 resolved that issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15506670&linkID=9242019
I'm not certain if this is the issue you're seeing, but it's somthing to rule out.
I hope that this helps.
Good luck with all of your Inventor pursuits,
Curtis
http://inventortrenches.blogspot.com/
Hi thanks for the reply
We have now updated to 2012 and the problem persists, if I change the cam for an ecentric wheel the transitional constraint works fine but he constraint on the cam only works on the part of the face selected for the constraint ie the lobe of the cam or the base circle I cant get it work on all of the cam face, the follower will rock back and forth on the obe but let the cam turn 360,I have attatched another Jpeg with shows the lobe of the cam highlighted for the constraint, should the entire face right round the cam be highlighted some how
thanks
Tony
@rcst.beedham wrote:....I have attatched another Jpeg
Tony
Attach assembly here.
