Inventor General
*Expert Elite*
Message 11 of 13 (47 Views)
Re: calculating distance using rectangle pattern
04-18-2012 08:40 AM in reply to: paulcasaqua
Spacing - you put the the desired relative distance between instances.
Distance - you enter the total distance and Inventor calculates the spacing between instances.
What you use all depends on design intent.
One advantage to Curve Length is it is geometry driven - if you change the model the features will adapt to the change.
This might also be wrong behavior depending on your design intent.
Where Curve Length spacing really becomes powerful is in curved (not straight line) driven patterns.
The Rectangular Pattern tool in really a mis-nomer where it should have probably been called the "Curve Driven Feature Pattern - Where Often the Pattern is Linear" tool, but I guess that name would have been too long.
Have you seen examples of curve driven patterns?
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
paulcasaqua
Message 12 of 13 (43 Views)
04-18-2012 08:51 AM in reply to: JDMather
Thanks JD
Thanks also for the PDF file
Paul
*Expert Elite*
Message 13 of 13 (41 Views)
04-18-2012 08:53 AM in reply to: paulcasaqua
The curve driven patterns are on pgs 16-18.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
