Inventor Forum
bottom plate helical staircase
6 REPLIES 6
882 Views, 6 Replies
I'm trying to draw a helical staircase with a bottom plate underneath the steps. Drawing it isn't a problem. I used a sweep with helical curve. Then I converted this part to a sheet metal. But then inventor doesn't want to unfold it. Does anyone know how I have to make a flat pattern from this one with the necessary bending lines?
Example .ipt and photo in attachment
6 REPLIES 6
CCarreiras
Hi!
In real world, this plate as to be deformed , not bended, therefore, inventor doesn't calculate this kind of deformation.
This is a plastic deformation, inventor can't manage this.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
I know, but do you have a easy solution to make a part similar to this wich is possible to make with bends?
mrattray
Have you tried using a lofted flange?
Mike (not Matt) Rattray
mrattray
in reply to: mrattray
Never mind, lofted flange wont work. I'll dig up the solution I had to use last time I had this problem...
Fair warning though: it's not pretty.
mrattray
Here's the thread to where I had a smilar application: http://forums.autodesk.com/t5/Inventor-General/Sheet-metal-development/m-p/3798033/highlight/true#M4...
Attached is the finished part that I sent to fabrication. It's a major PITA, but they were able to build it.
I think it will work if I work in a similar way.
Thanks!!
