Inventor General
Active Member
Message 1 of 4 (555 Views)
border made for A4 sheet,now i Need for A3,A2 sheet
555 Views, 3 Replies
12-03-2012 05:20 AM
i made new borde for A4 sheet and now when i am shifting to A3 Or A1, border remains same as A4 sheet size only changing.kindly reffer the  image attached.Kindly solve
*Pro
jletcher
Message 2 of 4 (540 Views)
Re: border made for A4 sheet,now i Need for A3,A2 sheet
12-03-2012 07:04 AM in reply to: viveksriramr
You would have to make a border for each size. Then if you want them to change automaticaly you will have to write some ilogic code to do this.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Expert Elite*
Message 3 of 4 (530 Views)
12-03-2012 08:08 AM in reply to: viveksriramr
If you don't need for it to be fully automatic - the solution could be as simple as double clicking on the correct boarder in the Drawing Resources>Borders to change after-the-fact of creating or editing the sheet.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Pro
sbixler
Message 4 of 4 (496 Views)
12-03-2012 06:03 PM in reply to: viveksriramr
In your border definition, you can dimension the border from the sheet corners.  This will allow it to stretch with the sheet size, as long as you don't mind
Since we stick pretty close to the ASME standards, though, which have differing border widths for different sheet sizes, we are not able to take advantage of this.  We have five different border definitions.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
