Inventor Forum
boolean
12 REPLIES 12
Message 1 of 13
soldanr
617 Views, 12 Replies
boolean
I my opinion I think that Autodesk is making a huge mistake about not giving the option of SIMPLE boolean operations in the .ipt file. It is a lot easier to boolean with different body parts in one file. I am coming from many years of modelling in CATIA and SolidWorks and I must say that it does make a huge difference when it comes to productivity. I would strongly suggest that Autodesk take a look into having this feature available in the future. I think it would be a great advantage over the competitors
12 REPLIES 12
Message 2 of 13
in reply to: soldanr
I may be missing something but what are you referring to when you say "simple boolean operations"? I don't recall needing more in terms of operations than what is available at the moment.... -- Rui "soldanr" wrote in message news:1625137.1099978294352.JavaMail.jive@jiveforum1.autodesk.com... > I my opinion I think that Autodesk is making a huge mistake about not giving the option of SIMPLE boolean operations in the .ipt file. It is a lot easier to boolean with different body parts in one file. I am coming from many years of modelling in CATIA and SolidWorks and I must say that it does make a huge difference when it comes to productivity. I would strongly suggest that Autodesk take a look into having this feature available in the future. I think it would be a great advantage over the competitors
Message 3 of 13
soldanr Join, Cut and Intersect are available with Extrude, Revolve, Sweep and Loft. I cannot think of anything else that would be needed. -- Cheers, Rob Singlehurst Quadro4 750XGL 44.03 Athlon XP 2600+ 1G RAM Win2K SP4 IV9 SP1 "soldanr" wrote in message news:1625137.1099978294352.JavaMail.jive@jiveforum1.autodesk.com... > I my opinion I think that Autodesk is making a huge mistake about not giving the option of SIMPLE boolean operations in the .ipt file. It is a lot easier to boolean with different body parts in one file. I am coming from many years of modelling in CATIA and SolidWorks and I must say that it does make a huge difference when it comes to productivity. I would strongly suggest that Autodesk take a look into having this feature available in the future. I think it would be a great advantage over the competitors
Message 4 of 13
I guess he is referring to a possibility to do boolean operations like cutting geometry of one part from another wothout having to use derived parts.
soldanr: You ARE aware that you can use boolean operations in derived parts? Although I'll admit it is rather cumbersome.
Message 5 of 13
Sounds like that is what he is talking about to me also. I agree with him. I miss the "toolbody" approach used in MDT and think derived parts are a PITA. Howard "jorgen" wrote in message news:33092854.1099995179694.JavaMail.jive@jiveforum2.autodesk.com... > I guess he is referring to a possibility to do boolean operations like cutting geometry of one part from another wothout having to use derived parts. > > soldanr: You ARE aware that you can use boolean operations in derived parts? Although I'll admit it is rather cumbersome.
Message 6 of 13
Hi soldanr, Like Rui, Rob and others mentioned (Thanks all), most volume generating features have the join, cut and intersect. Derived functionality also has these except the intersect. Today as we all know Inventor supports a single body in the IPT file. When we support multiple bodies in IPT, I can envision that we will have to look into booleans more closely. I might have missed your point. Please give some more specifics. Thanks. Shekar "soldanr" wrote in message news:1625137.1099978294352.JavaMail.jive@jiveforum1.autodesk.com... > I my opinion I think that Autodesk is making a huge mistake about not giving the option of SIMPLE boolean operations in the .ipt file. It is a lot easier to boolean with different body parts in one file. I am coming from many years of modelling in CATIA and SolidWorks and I must say that it does make a huge difference when it comes to productivity. I would strongly suggest that Autodesk take a look into having this feature available in the future. I think it would be a great advantage over the competitors
Message 7 of 13
soldanr
Hi Shekar
What you mentioned in the reply is what I am refering to. The fact that inventor only supports a single body in the IPT file makes a little more difficult to deal with. I am aware that we can use derived parts. Put all the boolean parts in an assembly file, then open a new IPT file and derive the parts with plus or minus, selecting what to subtract.
So in conlusion I have to create an assembly file that makes no sense to have it (cause I don't need it), and then I create another new file with the derived parts . I had to create 2 new files, and waste time, space, effort , patience....
I am aware that the extrude, loft, revolve... all of them offer the cut feature.... but how about if I want to make a modification in the part before I cut? Like a fillet???
Now you must used derived parts.
Don't get me wrong... Autodesk inventor is an excellent and impressive package. I am impressed with the contents, but if you guys have used CAD programs that support different body parts I will assure you that it makes a huge difference in productivity. and that is what CAD is all about...
Thank you
Rafael
Message 8 of 13
The attached image of a part shows 2 distinct "bodies" in one part file. But you probably would rather call them "Lumps". My question: What's the difference? (logically, not boolean) "Shekar Subrahmanyam[Autodesk]" wrote in message news:4190ec2c$3_2@newsprd01... > Hi soldanr, > >Today as we all know Inventor supports > a single body in the IPT file. When we support multiple bodies in IPT, I can > envision that we will have to look into booleans more closely. > > I might have missed your point. Please give some more specifics. > Thanks.
Message 9 of 13
Hi Rafael, We are fully aware of this need to have multiple bodies and booleans in the IPT file. Having had AMCOMBINE in MDT we understand its advantages. We are also aware of the fact that users need booleans in assemblies. JOIN and INTERSECT (where relevant) in assembly features and booleans between components. Thanks for your input. Shekar "soldanr" wrote in message news:25162362.1100021201220.JavaMail.jive@jiveforum2.autodesk.com... > Hi Shekar > What you mentioned in the reply is what I am refering to. The fact that inventor only supports a single body in the IPT file makes a little more difficult to deal with. I am aware that we can use derived parts. Put all the boolean parts in an assembly file, then open a new IPT file and derive the parts with plus or minus, selecting what to subtract. > So in conlusion I have to create an assembly file that makes no sense to have it (cause I don't need it), and then I create another new file with the derived parts . I had to create 2 new files, and waste time, space, effort , patience.... > > > I am aware that the extrude, loft, revolve... all of them offer the cut feature.... but how about if I want to make a modification in the part before I cut? Like a fillet??? > Now you must used derived parts. > > Don't get me wrong... Autodesk inventor is an excellent and impressive package. I am impressed with the contents, but if you guys have used CAD programs that support different body parts I will assure you that it makes a huge difference in productivity. and that is what CAD is all about... > > Thank you > Rafael
Message 10 of 13
From the users viewpoint there is not much difference I guess, though from a data structure and body management (and probably other) viewpoint there is . In your example its a SINGLE body with TWO LUMPS. Each lump (solid or surface) represents a disjoint set of points. In the multiple bodies case, its TWO BODIES with ONE LUMP each. Hope this kind of detail is not boring !!!!!!!!!. Thanks. Shekar "Bob S." wrote in message news:4190ff7b_1@newsprd01... > The attached image of a part shows 2 distinct "bodies" in one part file. > But you probably would rather call them "Lumps". My question: > What's the difference? (logically, not boolean) > > "Shekar Subrahmanyam[Autodesk]" wrote in message news:4190ec2c$3_2@newsprd01... > > Hi soldanr, > > > > >Today as we all know Inventor supports > > a single body in the IPT file. When we support multiple bodies in IPT, I can > > envision that we will have to look into booleans more closely. > > > > I might have missed your point. Please give some more specifics. > > Thanks. > > >
Message 11 of 13
soldanr
thanks guys for the replies. i hope i was not rude making my point but having different part bodies in the IPT file i think it is a must. Inventor offers some great advantages over the competitors, and I am sure that enabling this option will put the software in greater advantage. I hope to see this feature in the next release. Definitely a wishlist thing!
Cheers guys
Message 12 of 13
"Rob Singlehurst" wrote in message news:41907ee4_2@newsprd01... > soldanr > Join, Cut and Intersect are available with Extrude, Revolve, Sweep and > Loft. > I cannot think of anything else that would be needed. And coil ! Nick
Message 13 of 13
Thanks for raising the issue Soldanr - for me it comes under the heading of 'better not ask that - you'll just be told you're an old acadhead!'
Having frequently found difficulties which could have simple boolean answers I've finally learnt how handle/derive them (just) in Inventor - but with much muttering under my breath.
My vote for the wishlist!
Ralph
