is there any way to make all the rows in the BOM/parts list on an IDW the same height? I did a search on this and saw nothing new on this. the reason we need this is for a program we use after export to dwg. it is a program we use in autocad that is a txt copy lisp program to populate attributed customer title blocks.
Solved by cbenner. Go to Solution.
Can you post a screen shot demonstrating the varied row height in your parts lists? It may actually turn out to be the length of the column that needs adjusting.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
well that was too easy. We might have gotten that if not being a Friday before a long weekend.
thanks much
