Inventor Forum
blank ribbon & no text in Inventor screen
11 REPLIES 11
Message 1 of 12
PENengr
2904 Views, 11 Replies
After 2nd "clean install" we have no ribbon graphics or menu text on an otherwise recognizable Inventor screen.  This is true with the standard user as well as the Admin.  Phone consultation with our Autodesk vendor has not produced anything.  Do you have any ideas on this?
11 REPLIES 11
Message 2 of 12
Dennis_Jeffrey
in reply to: PENengr
What are the specs on your system - especially graphics? See this link for information that is needed to help.
http://teknigroup.com/support/Inventor/Howto.html
Standard Installation - Specific Instructions:
http://teknigroup.com/support/InstallAdsksoftware.html
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 3 of 12
Dennis_Jeffrey
Just a thought...
Post a screen shot if possible. Does it lool like this??
Message 4 of 12
PENengr
in reply to: Dennis_Jeffrey
Attached is a screen shot.
Computer specs:
Intel Core2 Quad
Q9450 @2.66GHz
2.66 GHz, 3.25 GB RAM
video card = NVIDIA Quadro FX 3700
Thanks, Greg
Message 5 of 12
Dennis_Jeffrey
Have you updated your graphics card driver?
Have you changed fonts in Application Options >> General tab? (Should be Tahoma 8 Pt by default)
Have you deleted any fonts?
Message 6 of 12
davegratto
I just got done working with one of my users that has this same issue. I found that if you delete the file C:\Documents and Settings\USER_LOGIN\Application Data\Autodesk\Autodesk Inventor 2010\RibbonUICustomization.xml. that the ribbon has the text back. Deleting the file is only a check and a work-around. The file "RibbonUICustomization.xml" is recreated on exit from the application. To resolve the issue I had to recreate the user's Windows profile, it has solved this issue on our system. I guess there is some corruption between the user's profile (registry SID) and the application. Don't know, just know what has worked for me.
Message 7 of 12
I'm having the same issue.  Tried the above fix, but still no dice.
I am running the latest graphic drivers for my radeon 1650
i have not removed any fonts or anything else.
I have cleared the Ribbon file from all of the profile users and from the registry.
Any other suggestions?
Message 8 of 12
rdyson
Without re-reading the entire thread, have you tried switching from the Ribbon to the Classic UI and back? Maybe close IV in between UI's.
PDSU 2016
Message 9 of 12
no i haven't tried that.  I'm not sure where to even go to do that... since i can't see anything.
Message 10 of 12
BMiller63
Applicaton Options > Colors tab > Interface Style
Message 11 of 12
in reply to: BMiller63
BMiller's solution is what solved the same problem (be it in AutoCAD) for a client of ours. Need to set the default to classic view.
Message 12 of 12
I had the issue on another computer and this did resolve it, but it still didn't on the original computer.  I ended up doing a reimage which took a long time using ghost to resolve it.  I hope i don't have to go that route again.
