Inventor General
Active Contributor
Message 1 of 3 (223 Views)
best method = conversion old .idw to new .dwg template
223 Views, 2 Replies
12-05-2012 11:24 AM
I want to convert our drawings from one template to another (attached).  Conversion is from .idw to .dwg. What's the best method?
Thanks, Greg
Dell T3500
Intel Xenon CPU
15 MB RAM
64-bit operating system
NVIDIA Quadro 5000
Product Support
Message 2 of 3 (200 Views)
Re: best method = conversion old .idw to new .dwg template
12-06-2012 01:18 PM in reply to: PENengr
You would not be able to convert one file extension to another in sometype of a transfer. If you are just looking to swap out the template information then you can try the "Drawing Resource Transfer Wizard" in the tools menu of the program group.
Don
Curtis_Waguespack
Message 3 of 3 (196 Views)
12-06-2012 01:32 PM in reply to: PENengr
Hi PENengr,
You can use Task Scheduler to convert your IDW files to DWG:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0698-Share_da69...
And then use the Drawing Resource Transfer Wizard previously mentioned, to add or exchange titleblocks, border, sketched symbols, etc.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0684-Collabor684/0725-Tools725/0...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
