Inventor General
*Adams, Brad
Message 1 of 1 (17 Views)
bend extents lines get turned on after changes in model
17 Views, 0 Replies
11-20-2002 02:00 AM
Does anybody else see this happen? I made a
sheetmetal angle and created a flat. I then created an IDW and place a view
of the flat pattern. I dimension everything out, everything is ok (no bend
extent lines on the flat.) I close out the IDW. I desided to make the sheetmetal
angle longer, so I make the changes in the IPT and save the file. Now I open up
the IDW and the bend extent lines are now onin the flat. I turn the bend extents
off and everything is fine. If I leave the IDW open and make a change to the IPT
the bend extents stay off. However it seems that if I close the IDW and make a
change to the IPT then reopen the IDW the bend extent lines are on again for the
flat.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
