Inventor General
wh
Message 11 of 19 (454 Views)
Betreff: ball pattern in BALL SCREW assembly
10-19-2012 11:43 AM in reply to: lis_wang
Here's my approach.
I've made changes to spindle and ball screw, and made an array of the balls.
In the end I tried to turn the spindle and move it through the ball screw, but no luck. I suspect, that this is another sample of Inventor's unsatisfying constraint capabilities.
Remark: I know, that normally the balls are moving, too, but I neglected that, because of simplification. And I know, that normally the spindle is axially fixed and just rotating, and the ball screw does the axial movement. I'm in doubt, if this version would be running better.
EOP of parts needs to be moved down. Files are Rel. 2012
Walter
Distinguished Contributor
Message 12 of 19 (427 Views)
10-20-2012 05:23 AM in reply to: wh
It is really a clever approach. By usin this method, I have to manually change the quantity of ball in BOM.
Thank you very much
wh
Message 13 of 19 (419 Views)
10-20-2012 05:45 AM in reply to: lis_wang
You can do the array as separate bodies as well, Lis.
But unless you're in ball screw manufacturing, you're ordering complete elements. It doesn't matter, how many balls are inside.
Walter
Message 14 of 19 (412 Views)
10-20-2012 06:13 AM in reply to: lis_wang
Pattern Component will give multiple instances of one ball.  (rather than having multiple balls in one part file)
I have assigned this problem to my class.
I will post my solution once they have attempted the solution.
oops, I keep forgetting you are on 2012 - well I'll post a screen shot when they get done.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 15 of 19 (405 Views)
10-20-2012 08:15 AM in reply to: JDMather
Thanks JD. I will try your approach as well.
wh
Message 16 of 19 (360 Views)
10-30-2012 12:06 PM in reply to: JDMather
Did you try the solution with your class meanwhile, Jeffrey?
Message 17 of 19 (354 Views)
10-30-2012 12:27 PM in reply to: lis_wang
Ah yes, we came up with a good solution, but I forgot about this thread.  I will try to remember to attach the solution tomorrow.  (what is left of a hurricane is sitting right over the top of my head today)
wh
Message 18 of 19 (346 Views)
10-30-2012 01:32 PM in reply to: JDMather
My best wishes for not too much damage by the storm.
Good to see, that you still have access to electricity.
Message 19 of 19 (340 Views)
10-30-2012 02:43 PM in reply to: wh
My wife is peddling the bicycle generator as fast as she can.
The wind has died down here, just some left-over rain.
We didn't experience any damage on our property, but I haven't ventured down the road yet to check the neighborhood.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
