Inventor General
Distinguished Contributor
Message 1 of 7 (56 Views)
back in the day, degrees of freedom
56 Views, 6 Replies
12-16-2002 09:55 PM
I seem to remember a RMB when selecting a part that would illustrate a degrees of freedom of a part in an IAM. Did this disappear or am I just not remembering correctly. I have a part that is critical (well that is overstating it a bit) to its location. I feel that it can not move (due to its contraints) but the not "movable" symbol will not come up when I try to pull it in the IAM so I tried to look where it can move. I was sure I use to RMB and find a degrees of freedom option and then a symbol used to come up on the part indicating the way that the part might be able to move. Any ideas?
*Caldwell, Larry
Message 2 of 7 (56 Views)
Re: back in the day, degrees of freedom
12-16-2002 10:06 PM in reply to: accu-cad
You can turn it on in the View menu. Unconstrain
something and it should show an arrow in that direction.
~Larry
I
ideas?
*Dotson, Sean
Message 3 of 7 (56 Views)
12-16-2002 10:10 PM in reply to: accu-cad
View/Degree of Freedom.  If the icon does not
appear on a part it has no DOF...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
I
ideas?
Message 4 of 7 (56 Views)
Re:
12-16-2002 10:24 PM in reply to: accu-cad
thanks
Message 5 of 7 (56 Views)
Re:
12-16-2002 10:25 PM in reply to: accu-cad
that only makes perfect sense thanks
*Autodesk\
Message 6 of 7 (56 Views)
12-17-2002 12:31 AM in reply to: accu-cad
Select the component, RMB, select Properties,
select Occurrence, check the Degrees of Freedom check box to display the DoF for
that selected part (otherwise as others have mentioned, View menu will toggle
the DoF on/off for all of the (first-level) components in the
assembly.
G
Message 7 of 7 (56 Views)
Re:
12-17-2002 01:15 AM in reply to: accu-cad
Oh so it is burried under properties. That is ok too. I don't use it often so either method of finding it is good. Thanks "G"
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
