ok i know this sounds stupid but i down graded inventer to 2012 i like that one much better but i had files saved for the 2014 version is there anyway i could change those
nope no saving down in inventor
you would have to export the files out .step or iges then import back into 2012 but you will lose the feature history
DarrenP
ok i have no clue how to do it so could you do it i will attach the file
Its as simple as "save copy as" and save it as a step file..
But how many do you have that are in the 2014 format.. And realize what he said.. You WILL loose the feature/history tree (aka model browser) and NOT be able to edit the individual features..
It is ALWAYS a smart idea to backup ALL cad files before migrating and saving those backups so that you can easily revert to them if you need to.
File > Save As > Save Copy As
Under Save as type, select STEP
Click Save
I don't understand what the difference is between 2012/2014 that I would go back to 2012, but you can have both releases installed on the same machine (if you are a student or if you are on subscription).
I noticed that some of your sketches are not dimensioned and that if I add the missing dimensions they do not make logical sense.
I would be be careful with this file.
of course not it is a rough skech and it is not finished i have to make a finle one for meggit if you have ever herd of them
You will have to start over in 2012 or go back to 2014.
Even if you got these into 2012, it would be very difficult to find what has and what has not been dimensioned.
