Inventor General
Distinguished Contributor
slphantom
Message 1 of 5 (349 Views)
Accepted Solution
auto project datum planes
349 Views, 4 Replies
07-13-2012 12:38 PM
is there a way to auto project datum planes that are square to the sketch?
just wondering.
thanks
Scott
win 7 64 bit sp1
cpu intel xeon E5-2687W0@3.106
eight core
two solid state hard drives
32 gig of ram
Autodesk product design
suite premuim 2014 64bit
Nvida quadro 4000
Space Pilot ver. 1.6.2 2010
slphantom (NNTP handle: scottl)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as scottl
*Expert Elite*
cwhetten
Message 2 of 5 (342 Views)
Re: auto project datum planes
07-13-2012 01:14 PM in reply to: slphantom
I wish there was, since this is my preferred method of constraining to the part origin.  Instead, I had to create part templates with the first sketch having the projected planes, one template each for sketching on the XY, XZ, & YZ planes (see attached).  I put the 0 in front of each template name so that they show up first in the list of templates.
*Expert Elite*
Curtis_Waguespack
Message 3 of 5 (324 Views)
iLogic Project All Work Planes
07-13-2012 02:35 PM in reply to: slphantom
Hi slphantom,
Attached is an example file with an iLogic rule in it that might work for you. If you create an external iLogic rule with this code you'll have it available to run on any file.
Note that you need to be in a sketch edit for the rule to work.
I hope this helps.
Curtis
If Typeof ThisApplication.ActiveEditObject Is Sketch Then
'Do nothing
Else
MessageBox.Show("Activate a Sketch First then Run this Rule", "ilogic")
Return
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oSelectSet As SelectSet
oSelectSet = oPartDoc.SelectSet
oSelectSet.Clear
'look at the workplane collection
'and add each workplane to the select set
For Each oWorkPlane In oPartDoc.ComponentDefinition.WorkPlanes
oSelectSet.Select(oWorkPlane)
Next
'Project Geometry
ThisApplication.CommandManager.ControlDefinitions.Item("AppProjectGeometryWrapperCmd").Execute
'Cancels active command
ThisApplication.CommandManager.StopActiveCommand
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
Curtis_Waguespack
Message 4 of 5 (316 Views)
Re: iLogic Project All Work Planes
07-13-2012 02:57 PM in reply to: Curtis_Waguespack
Here's another version that only projects Origin Planes.
'Do nothing
Else
Return
oSelectSet.Clear
'find origin planes only
If oWorkPlane.IsCoordinateSystemElement = True Then
Next
'Project Geometry
z.baczo
Message 5 of 5 (181 Views)
02-28-2013 11:56 PM in reply to: Curtis_Waguespack
Sorry for bringing back to life an older thread but I'm also interested in this functionality.
What i'm interested in is: Is there a way to create a button on the ribbon (or a shortcut key) for this?
Maybe a macro or something? (I'm not very familiar with macros, not sure if it would be possible or not...).
Thanks in advance,
B.
(Inventor 2013).
Baczó.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
