Inventor Forum
auto project datum planes
4 REPLIES 4
slphantom
708 Views, 4 Replies
is there a way to auto project datum planes that are square to the sketch?
just wondering.
thanks
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
4 REPLIES 4
cwhetten
in reply to: slphantom
I wish there was, since this is my preferred method of constraining to the part origin.  Instead, I had to create part templates with the first sketch having the projected planes, one template each for sketching on the XY, XZ, & YZ planes (see attached).  I put the 0 in front of each template name so that they show up first in the list of templates.
Hi slphantom,
Attached is an example file with an iLogic rule in it that might work for you. If you create an external iLogic rule with this code you'll have it available to run on any file.
Note that you need to be in a sketch edit for the rule to work.
I hope this helps.
Curtis
If Typeof ThisApplication.ActiveEditObject Is Sketch Then
'Do nothing
Else
MessageBox.Show("Activate a Sketch First then Run this Rule", "ilogic")
Return
End If
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oSelectSet As SelectSet
oSelectSet = oPartDoc.SelectSet
oSelectSet.Clear
'look at the workplane collection
'and add each workplane to the select set
For Each oWorkPlane In oPartDoc.ComponentDefinition.WorkPlanes
oSelectSet.Select(oWorkPlane)
Next
'Project Geometry
ThisApplication.CommandManager.ControlDefinitions.Item("AppProjectGeometryWrapperCmd").Execute
'Cancels active command
ThisApplication.CommandManager.StopActiveCommand
Here's another version that only projects Origin Planes.
'Do nothing
Else
Return
End If
oSelectSet.Clear
'find origin planes only
If oWorkPlane.IsCoordinateSystemElement = True Then
End If
Next
'Project Geometry
z.baczo
in reply to: Curtis_Waguespack
Sorry for bringing back to life an older thread but I'm also interested in this functionality.
What i'm interested in is: Is there a way to create a button on the ribbon (or a shortcut key) for this?
Maybe a macro or something? (I'm not very familiar with macros, not sure if it would be possible or not...).
Thanks in advance,
B.
(Inventor 2013).
Baczó.
